Wiring Components Properly
  • 4
NOOBALICIOUS
First time installer here. I've finished "prepping" the front stage (i.e. installed Dynamat in the front doors on the outer and inner skins and ran RF wiring from the Front doors to the trunk where the amp will go).
So it's time to install the components and I was wondering if I should use the speaker wire leads that are soldered on the components or if I should replace them with the RF wiring that I ran....or if it really matters? I'm not sure if the the higher gauge speaker wire leads would bottleneck the throughput or not. Thanks.
If you have better wire and time, run it. Is it real dynamat or a different brand? Dynamat is good, but overpriced //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
What speakers are you using and what amp are you powering them with?
Yeah, I got a pair of JBL P963 coaxials for the rear for backfill. I know a lot of people will argue that you don't need them/won't hear them/won't use them etc. but I'd rather have the option to hear how it sounds before I disregard it all together.
I wouldn't mind some more opinions on the original question I had about the component speaker wire leads. I've searched this site up and down and have never seen that question brought up so hopefully some more experts here will chime in.
Unless you have good soldering skills, I don't recommend replacing that factory set up. All in preference though. Just crimp some ring terminals on and screw them down, imo.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
186
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
587
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
626
641
551
NOOBALICIOUS
NOOBALICIOUS
Juno Beach
Jeffdachef
