Wiring Diagram req for Delco from 2002 Buick
  • 2
Hi. I've got a Delco CD and radio tuner (Delco part number 16249434) that I pulled from a 2002 Buick. I need to obtain a wiring diagram, so I can install it into a camper.
I've not had much luck with my Google-fu. If you have a wiring diagram for such a beast as this, I'd appreciate it greatly if you would be kind enough to share.
Thank you!
I think 2002 and older have same wires, you can just cross refrence to see if it is.
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black/White
Stereo Radio Illumination Wire: Gray/Black
Stereo Radio Dimmer Wire: Brown/White
Stereo Radio Antenna Trigger Wire: Dark Green
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Something like this? I just googled 2012 kia sportage stereo schematic diagram
Just go by color to color. LF, RF, LR, RR are your speaker wires. Positive + and Negative ( black stripes ). White, Gray, Green, Purple in...
I have a 2022 Cadillac with a factory Bose amp and am in need of the speaker wiring diagram so I can connect a hi lo converter.
The 2 channel amp has a built in cross over that can be set for low frequencies. If you post a picture of the crossover section, we could get a...
13
5K
jomlabr
jomlabr
Toronto, Ontario, Canada
los33
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
