Wiring harness 2012 Challenger
  • 2
dart_man440
Ok, please bear with me, I got a question and I have not been able to find an answer.
I will be installing a couple of amps and speakers in my challenger using the existing HU. I don't want to cut wires and want to keep the harness intact. What I want to do is get a harness adapter to the radio and a reverse harness adapter to the main harness. In other words, an extension per se, only that the speaker leads will not be connected and instead I will be running them straight to a JL Cleansweep.
I have not been able to find a harness adapter, I called Crutchfield and they recommended tapping the harness at the radio and Best Buy had no idea and they referred me to Autozone (What ever). Anyone run into this issue? A search led me to the Metra 71-6522 which plugs into the OEM HU and it looks like it will work, how ever, I can't find the the mirror harness that plugs into the main harness. Any help will be greatly appreciated. Thank you,
dart.
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
So is the radio harness spliced direct to the OEM harness? There is no adapter harness?
12
If the plug matches, you just need to match the wires up. I re-made the harness for my audison amp, and the hardest part was getting the speaker...
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
dart_man440
dart_man440
Douglas, Arizona
dart_man440
