Wiring Harness Troubles
  • 3
Zeditious
13
TN
I have a 2008 Silverado Ext. Cab without the bose system in my vehicle. I purchased a Pioneer Head Unit and a Axxess GMOS-LAN-02 wiring harness without doing much reading. I realized after looking at the packaging that the GMOS-LAN-02 supports amplified systems (aka Bose Audio) systems but doesn't specify if it supports non-amplified systems. Should I go ahead and exchange it for a GMOS-LAN-01 or try the current one?
Your factory system might have a factory amp somewhere hidden that powers the speakers in your truck. Might have to remove the factory wiring harnness and splice those wires to hook on the spkr wires on the new HU.
According to Crutchfield I do not have the right wiring harness. I can't seem to find any results that really specify what I am looking for on Google. Should I return the Harness and wait until next week and order a new one or should I try this one? My only concern is that if I get too far into it won't be returnable.
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
978
So is the radio harness spliced direct to the OEM harness? There is no adapter harness?
12
If the plug matches, you just need to match the wires up. I re-made the harness for my audison amp, and the hardest part was getting the speaker...
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
Zeditious
Zeditious
TN
huberoy123
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
