Wiring help and opinions with dvc subs
  • 4
StyrofomE CuP
Recently bought the amp and 2 subs from a friend's relative for cheap. I've looked everywhere online for a situation like mine but didn't find anything; amp stats and sub stats below, putting the subs in a sealed box/boxes. The options I thought of also below.
I have a Crossfire vr1000d mono amp rated at 12.5v instead of 14.4v:
250w rms at 4 ohms
500w rms at 2 ohms
1000w rms at 1 ohm
*It has supposedly been modified to put out 1800w at 1 ohm.
The subs are two 12" Selenium Extremes:
2 ohm DVC if only i had 4 ohm dvc //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
650w rms each
Wiring options I need opinions on:
1) Wire the DVC subs for a 2 ohm load which would take 1300w rms from a "500w rms at 2 ohms" amp. (under powering the subs which i know is worse than overpowering)
2) Only wire one sub at 1 ohm (the amp will be almost 3x it's rms though)
3) Wire the subs for 0.5 ohms. (would be able to use both subs with perfect amount of power. Worried about the amp though)
I'll be grateful for any advice and opinions! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
THIS^^^^
its not "underpowering" that hurts subs. it using the gain as a volume knob that burns up voice coils.
i would run your subs @ 2 ohms until you can buy an amp, that does the power you want @ 2 ohms, or buy subs that you can run @ 1 ohm.
Under powering a sub is never going to hurt a sub.
Very true.
Its the person behind the volume knob of that under powered sub that will cause it to get hurt.
The amp was "moded" for more power @ 1 ohm?
Hmm...
IIRC, @ 14.4v, that amp should be near that area.(something like 1500ish 2 14.4v)
Would you happen to have or can take some gut shots for us??
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
676
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
StyrofomE CuP
StyrofomE CuP
Baton Rouge
thevic24
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
