Wiring help... im cunfused...
  • 5
DB-Audio
Syko DJ music producer
2,677
Newtown, CT
So I had 8 gauge wire wired up with no fuse on low power and my amps work fine no problem, well I change the 8 gauge to 4 gauge and all hell breaks loose... I start popping fuses every time I try to hook the amp up whats wrong? I have power to the amp it wont turn on though it (knock on wood ) hasnt smoked yet, but the fuses keep blowing. with no out put. the amp im using is a audiopipe 1300mini
Sounds like you have power wiring/strands maybe grounding out,blowing fuses to me..Check make sure no loose/exposed strands are present,grounding out on power the wire.Check your power run see if you have cut the jacket on the wiring going through the fire wall also...possibly may have cut and exposed the wiring there?
could also have power and ground backwards on the amp. this will blow any size fuse instantly.
LOL..I couldn't tell you how many times ive crossed power and ground wires over the years..It does happen..Thats for sure
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
457
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
857
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
940
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
DB-Audio
DB-Audio
Newtown, CT
NASTY08IMPALA
Brendon Jenness
    May 8, 2024
    May 8, 2024
