Wiring help
  • 2
Hey guys,
i have is 2 12" DVC 4 ohm subwoofers. I also have a 2 channel 2000 watt (bridgeable, 2ohm stable) amp. I currently have it wired at 4 ohms 350 watts RMS to each sub. My question is, what would be the best way to wire my subs to get the most power out of the amp? Should i bridge the amp, and would i be getting 2000x1 (1000x2). Also, is it safe to bridge it? What are the risks?
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
682
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
conbon
conbon
Cincinnati
conbon
Decebal
    Jun 10, 2024
