Wiring Issues, Please Help
  • 4
jmann83
Okay so bought a head unit about 10-12 months ago and installed it, and everything worked wonderfully. Now for about the past 3 months or so my stereo works intermittently it cuts on about 1/4 of the time i start my car or some times at random while driving then just randomly cuts off. When I try to eject a CD or hit the display button it will preform either one of those functions then goes off. I just had time to get in there and screw around with it. I have checked all my connections to make sure nothing was grounding out, I also check and re routed my grounding to make sure that wasn't an issue. I have checked my fuses to make sure nothing was only partially plugged in or blown. I'm kind of at a loss for what to do now. Any suggestions would be greatly appreciated. Thanks
if it has a detachable face make sure the faceplate is making a good connection to the unit, use alcohol swaps to clean the connection pins
good point I didn't think about the fact that he said it cut completely off, I had a really similar issue once upon a time and it was a grounding issue, you said you relocated your ground wire, when you picked your grounds did you meter the voltage from the constant to the ground you used... what kind of vehicle is, some has weird grounds
Its a 99' Pontiac TransAM. I ran a temp wire from the head unit through the firewall of my car and connected it the the chassis of the car just to make sure i had a solid ground that something else was hooked to. When I ran the temp ground it still had the issue. I beginning to think its just the head unit its self.
If the plug matches, you just need to match the wires up. I re-made the harness for my audison amp, and the hardest part was getting the speaker...
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
273
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
667
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
690
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
685
jmann83
jmann83
Pulaski, VA
All_Logix
