Wiring Kit Recommendation?
  • 3
jaguax
Hi guys, I just purchased all new speakers, Focal 165V components for the front and Infinity Kappa 63.5i's for the back.
My amp is an Eclipse 32440. Here are the specs:
200W x 4 Channel Max. Power Output at 2 Ohm Stereo
120W x 4 Channel 0.1% THD at 2 Ohm Stereo, 20-20,000Hz@13.8V (RMS Continuous Power)
85W x 4 Channel 0.1% THD at 4 Ohm Stereo, 20-20,000Hz@13.8V (RMS Continuous Power)
And if you need to know my head unit is a Sony CDX-M850MP(please don't make fun //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif)
So now I need to purchase a wiring kit with enough wiring and stuff for 4 channels. Which one though? Can someone make a recommendation? What guage do I need? Brand? Sorry I'm a n00b I don't know much about this stuff.
Thanks for any help, I appreciate it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Don't I also need 4 RCA/Interconnect cables? I notice most amp kits only have 2? And what about the battery post thingy? Don't I need one of those? A lot of kits don't even have those.
Also how many watts does the wiring kit have to be rated to work with my amp? I'm gonna be using 85x4 @ 4 ohm so does that mean I need at least a 340 watt capable wiring kit?
Thanks for any advice!
Just run the rear doors off the head unit and get a set of components for the front instead to use on the 4 channel. If you want a subwoofer down...
677
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
225
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
631
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
665
jaguax
jaguax
New York
blushadow_db160
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
