Wiring Kit
  • 2
what size fuses would i use for the inline fuse and the fuse box, i have a 250 W amp for a sun and a 4 channel amp with 80W per channel.
Just run the rear doors off the head unit and get a set of components for the front instead to use on the 4 channel. If you want a subwoofer down...
666
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
95
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
360
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
354
Durastar
Durastar
Maryland
Durastar
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
