Wiring Tweeters???
  • 5
I know I am going to catch Hell about this from people that don't understand where I am coming from, but you actually want a heavier gauge wire for the same length of run, for the same power thant you do for a mib-bass speaker. If you are running active and have a long run all the way back to the trunk, it can't hurt to go ahead and use 12 AWG. If you want a better explination as to why the smaller speaker needs more wire, PM me and I can fill you in
Are you hinting at higher frequencies generating a greater skin effect.... ?
Id like to see this.
1000 points to Flex. Depending on the wire though you could get laminated strands which will help cut this down.
EDIT: I noticed I wrote 12 AWG in the first post, for 60 Watts, you should be fine with 16. Sorry about that
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
94
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
360
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
354
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
4
667
trenthonda1
trenthonda1
Florida
All_Logix
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
