Wiring up 5 Dorman 628-040 Heated seat kits. Opinions needed.
  • 2
MxRacer476
Hey guys,
I have installed Katkinz Leather Seat Covers in my new truck I picked up, and I have also installed 5 Dorman Universal Heated Seat Kits (628-040). Which are 10A fused to a switched 12v ckt with a relay. They want you to use a fuse tap to gain power. However since I have 5 I would like to know if I can run a 12AWG ling to power this fuse/distribution block. Then just use there switched B+ line to tie into this block, or what the best way is to go about it?
I have attached links to the Dorman Kit, and the Distribution/Fuse Block I want to use.
Block;
http://www.amazon.com/dp/B00QMTAZ1W/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=WQ5MRQAKFPE4&coliid=I11FLV9GUM7QF6&psc=1
I made a similar post in the misc electrical section 5 days ago but only have tons of views, no replies. This coming week I have off, and would like to knock out the wiring before the temps fall off here in Illinois, and I return to work for a few months...
Dorman 628-040 pdf
http://www.dormanproducts.com/digitalassets/document/628-040_IS.PDF
Thanks Scott,
Yes I will use each harness supplied with the kits, and keep them individual legs to the elements. Plan on locating the distribution block under my center console.
What size fuse should I use in the line feeding the block do you think, keep it to a 10?
Relays in the harnesses are 12V 40/30A
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
202
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
602
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
644
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
648
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
557
MxRacer476
MxRacer476
Georgetown, IL
MxRacer476
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
