Wiring up an SMD vm-1
Denial-
CarAudio.com Recruit
61
Pa
I just got one of those analog led volt meters by smd and wanted to put it in. Just wanted to make sure first that I'm correct in thinking I can just run long runs of regular 18 Guage from the wire harness from the head unit to the meter itself right? The instructions say red is + black is ground and yellow is remote turn on so I'd just wire red to + on the head unit harness black to ground on there and then just tap into the turn on for the Amp correct? Just wanna make sure im doing this right before doing it all the wrong way and it not working lol thanks guys.
I would wire it to your amplifier or battery.
Yellow on the remote wire from the headunit to amp.
Red to amplifier positive or battery positive
Black to amp ground or battery ground.
Oh ****, so don't use the head unit harness and splice into the wires like that from them? Go directly to the battery with the postive and negative? I could still use the remote turn on from the head unit harness for the remote turn on for the meter though right? Only reason I'm asking is because I'm getting ready to put in a new head unit anyway and wanna just wire it up at the same time im doing all that just do it all together at once. Thank you for the reply to man.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
141
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
538
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
585
616
532
Denial-
Denial-
Pa
audiobaun
