wiring??
  • 1
depending on how you run them, if you run them in parallel i.e. + to + and - to - , connect the 2 +'s to the amplifer on the appropriate terminal for Bridging the Amp, and the same goes for the -'s. This would give the load of 2 ohms to the amp. Wiring the subs in series 2 4 ohm subs will equal 8 ohms. Wiring in series is the + for bridging goes to the + or the first sub then the - of that sub is connected to the + of the 2nd sub and the - of that goes back to the amp. Now this will present a large load for the amp and I would not suggest using the Series wiring. Now it comes down to does your amp handle a 2 ohm load? If the 2 speakers were Dual Voice Coils with 2 4 ohm VC's, then with the 2 speakers it would be a 4 ohm load to the amp. Confusing???? check this page out for answer to all of your many man questions //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifhttp://www.eatel.net/~amptech/elecdisc/caraudio.htm
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
199
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
600
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
641
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
648
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
556
Guest
Matt
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
