NeverEnuffBass 10+ year member
Got Bass?
- Thread Starter
- #301
They are already running at 1 ohm. May be time to find some .5 ohm or .25 stable ampsha...or another solution is to wire your amps down LOW.
They're barely moving, probably because the bassline in LNT is around the claimed tuning freq.And it could also be due to impedence rise.
Put two memphis 4,000 watt amps on em' and watch them go up in a smoke show.
I see what you mean by mine not being a built in wall. I just don't want to ruin the car. but its not like there are just 2 boxes laying there. I was thinking 20 cubes myself. I may try to cut down the existing boxes.dont know how to put this..but, build an actual wall...
do like 20 cubes w/ ~200^2"s of port....
x2+5458789441564dont know how to put this..but, build an actual wall...
Dont get too upset, you cant expect the first box these are in to be the best.Ok, 80INCHES brought over his multimeter this weekend and we properly set the gains on the amps. It is a tiny bit louder but I'm not happy with the results. I've heard a pair of 12's hit harder and deeper. Thinking about smaller boxes, ***** that I wasted 4 sheets of MDF and 10yds of carpet and gallons of resin on these...
I built out my acura legend...and you cant tell i ever had anything in there. Just be careful.I see what you mean by mine not being a built in wall. I just don't want to ruin the car. but its not like there are just 2 boxes laying there. I was thinking 20 cubes myself. I may try to cut down the existing boxes.
Thats how it is a lot of tight fitting beauty panels.I built out my acura legend...and you cant tell i ever had anything in there. Just be careful.
Take all the measurments, build it outside the truck...disassemble it, and reassemble it inside the truck. As far as the beauty panels go, you dont have to have it completely sealed off..i didnt. I sure as hell wasnt doing the spray foam route.
