Would it be possible to turn this into a 6th order
  • 5
Bass so loud it HZ
CarAudio.com Regular
I had a guy build me a wall and it's similar to a 6th just doesn't have a front port so right now its pretty much just a ported wall. I believe it can be done no problem. what do you guys think ?
Yeah I'm not that knowledgeable on all this stuff man . And I play it with one window down if not it's not as loud but it is louder at higher freq sealed .I paid alot of money to have this built . It was supposed to be a 6th order but dude messed up and built it for 2 18s . Then had to tear the baffle and all that out and this is what he came up with .
I haven't even attempted to play that high I've went up to 55s and I mean it plays but it's not loud
Well, best of luck figuring it out. Stinks that happened to you.
If you could wire to 2 ohms, you could see if sub movement is stressing the amps too much at .5. You’d see how it plays wired higher, especially comparing db changes over a range, because playing away from tuning can cause way more stress on the amp, which causes the amp to electrically not be able to handle energy from the coil moving more from the woofer unloading, basically. You could try some things like that too. I don’t think any of this is going to be particularly simple or easy to figure out with all of the factors.
Thanks !! Just curios what would you recommend setting the hpf at for this enclosure ?
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
418
Hmm.. No Bueno. Id prob be looking at another set of subs to be honest. Like some American Bass DX series. Great subs for the $. Maybe even look...
8
662
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
11
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
It's easily possible, but not easily practical, aesthetically pleasant, or efficient. It is as easy as adding a dc power supply (i like megawatt...
5
Bass so loud it HZ
Bass so loud it HZ
IN, United States
Buck
Latest topics
