WTB Ballast
  • 4
argenis69
SQ Bass Lover
844
NY, USA
Hello,*
From your experience I would like to know:
1- Which is the best and recommended 55w hid ballast to buy, with real 55w output and at a decent price?(please provide website if possible)
2- If i have already have a 35w hid kit, Will only changing the ballast to 55w do the trick?
3- Will these 55w hid kit do any harm, damage or melting to my Morimoto Mini D2S Projectors?
Thank you in advance.
You seem to have already done business with theretrofitsource.com. I use Morimoto Mini H1 6.0 projectors and TRS 5,000K bulbs with Racesport CANBUS compatible ballasts. Call TRS 404-220-7940, they will take care of you.
Are yours 55w hids?
No, 35W. I have had 0 need for more powerful lights now that I have good projectors, and that is with me driving on rural 2-lane roads where everyone is watching for deer.
That's good to know. Can you send me a video or link on detailed instructions on how to install my mini D2S projectors on my 2002 Nissan Maxima SE?
Would not recommend 55watts with any of the mini projectors personally. You run a high risk of burning the bowls. If you really want to run 55watts I would Highly recommend running OEM D2s bulbs.
Ive ran Morimoto bulbs and ballast on my car and truck for years with zero problems.
Done quite a few retrofits as well.
DDM is the Boss audio of HIDs.
Ok, Morimoto it is.
And you said to use oem bulbs, won't the color be to yellow?
I've heard that when you go to 55w ballast the color tends to be different, is it true?
Ok, Morimoto it is.And you said to use oem bulbs, won't the color be to yellow?
By OEM I mean Philips 85122 D2S bulbs. They are 4300k. Put out 3200 lumens. They come OEM in a lot of luxury cars.
Yes 55watts tends to be a little lighter in color then 35watts. A 55watt 6000k will look like a 5000k 35 watt most of the time(depending on quality of ballast and bulbs)
The higher in Kelvin you go the less light output you will get though. 4300k will get you the most output but with a hint of yellow.
I run 5000k (3000 lumen output) which is pure white. But my cutoff has a nice blue/purple in it.
Ok,
1- Are you using 55w ballast? With 35w hid bulb?
2- Since we know that the best output is at 4300k on a 35w ballast and the color changes with the 55w ballast, what color k hid bulb should i get to achieve the best light output on the 55w ballast?
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
295
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
665
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
7
  • Locked
I can get this to somewhere in NJ in US. Is that possible for you to ship that out ?
12
argenis69
SQ Bass Lover
argenis69
NY, USA
argenis69
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
