SOLD WTS: 10" Sub w/box, MP3 headunit, JL amp
  • 1
Caddyman
I just traded the wifes civic on a new truck and i need money ASAP for the down payment on it....lol
i will let it go as a lot for $425....LMK people
and im in delaware and can go almost anywher in the tristate if you wanna do the deal in person
i have
1 - slightly used 10" kicker comp in custom vented box with grill (50-300 watts RMS) (9 out of 10)($100)
1 - slightly used 6-channel JL amplifier, the stupid sub box fell over on it and scratched the face of it, but it is mechanically perfect (8 out of 10) ($250 obo)
(specs)
6-Channel Class-AB System Amplifier
Absolute Symmetry Class AB Circuit
Differential, Noise Cancelling Input Topology
RMS Power Output:
45 Watts x 6 Channels @ 4 Ohms
75 Watts x 6 Channels @ 2 Ohms
90 Watts x 3 Channels @ 8 Ohms (Bridged)
150 Watts x 3 Channels @ 4 Ohms (Bridged)
Variable High- / Low-Pass Filters: 50 - 200 Hz
Adjustable Input Sensitivity: 200mV - 8V
Bass EQ on Channels 5 & 6: 0 / 6 dB
0 - 12dB Bass Boost with RBC-1 Bass Control (Sold Seperatley)
3 Pair RCA Stereo Inputs
4-Channel High Level Inputs
Channel 5&6 Sum / Discrete Input Switch
Unregulated MOSFET Switching Power Supply
Dual N-Channel MOSFET Output Design
External 60 Amp Fuse Required
Dimensions: 17-3/4" L x 9-1/4" W x 2-5/16" H
1-year Sonic Electronix warranty
Amplifier Specifications:
Number of Channels: 6
RMS Power (4 ohms): 45 watts x 6 chan.
RMS Power (2 ohms): 75 watts x 6 chan.
RMS Power (1 ohm): Not Stable
Bridged RMS Power: 150 watts x 3 chan.
Peak Power Output: 900 watts approx.
Min. Impedance Unbridged: 2 ohms
Min. Impedance Bridged: 4 ohms
THD @ Rated RMS Power: 0.08%
Speaker Level Inputs: Yes
Amp Preamp Outputs: No
Built-in Crossover: HP / LP (50 - 200 Hz)
Bass Boost: 0 - 6 dB
Signal-to-Noise Ratio: 104 dB
Fan Cooled: No
Fuse Rating: 60A External
1 - panasonic mp3/wma head unit (8 out of 10) no scratched or dings/dents on it. ($120)
183
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
531
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
565
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
658
Caddyman
Caddyman
Delaware
Caddyman
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
