slammedincouch 10+ year member
1. Product:
(2) AT Strato 18s Dual 2
2. Specs:
D2
3" Voice Coil
Re: 4.0 ohms
Fs: 30.3 Hz
VAS: 205.1 L
Le: 2.01 mH
BL: 17.6 NAQes: 0.63
Qms: 6.76
Qts: 0.58
Mms: 254.5 g
RMS: 400 Watts
3. Description/Condition:
Cosmetically 9/10 as they've been installed, Mechanically 10/10. If you've been following my build log, I've had them installed for the past 2 weeks. I've only been able to get at most 45 minutes of play time on them (things have kept me from finishing the amp rack). Pair has seen ~1100 watts total and didn't even get warm.
Reason for selling? Mostly just suspension issues- my truck is sagging pretty bad on the stock leafs and shocks (only thing that's been upgraded so far are the shackles). That and it's my winter vehicle and I'd prefer to go back to something below the window line.
4. What you are looking for: :
Seeing what's out there- I like to try new stuff. I would like to keep this as a strict trade deal and I'm looking to trade for a single beefy 15 or possibly an 18, maybe two 12s depending on what they are. Single subs need to be D2, if it's a pair of 12s then D4.
MAY consider selling, but I'll probably just keep them for when I get the suspension more beefed out if I don't see any trades I like.
5. Pictures of your item for trade:
Took the pictures yesterday and forgot to post the thread over here- if there's any issues I can retake them.
My DMM Reads off between .7 and .8 here are the leads touching to show this
2. Specs:
D2
3" Voice Coil
Re: 4.0 ohms
Fs: 30.3 Hz
VAS: 205.1 L
Le: 2.01 mH
Qms: 6.76
Qts: 0.58
Mms: 254.5 g
RMS: 400 Watts
