WTT 2 Channel Amps!
  • 3
snoop3111
1. Product: MTX 91002 and Boston Audio GT275
2. Specs:
MTX 91002:
# of Channels 2
Minimum Single Channel Impedance 1
Class A/B
Amp Type Full Range
Power Supply Semi Unregulated MOSFET
THD + Noise (1 Watt) 0.1%
Signal-To-Noise Ratio (1 Watt)71 dB
Overload Protection
Thermal Protection
Xtant Technology Cooling
Continuously Variable Fan Speed
Connection Terminals
StreetWires Connectors
14.4VDC Power
4 Ω 250W x 2
2 Ω 500W x 2
1 Ω 750W x 2
4 Bridged 1000W
2 Bridged 1500W
INPUT (RCA Connection)
Low Level x
Hi Level w/ Smart Engage
Input Sense 100mV-1V/1V-10V
GAIN CONTROL Individual - 100mV-10V
CROSSOVER Hi,12dB / Low, 24dB Mono @ 40Hz-350Hz, Defeat
SubSonic @ 30Hz, 12dB/oct, Defeat
EQUALIZATION Parametric: Boost/Cut +/-12dB, Freq. 30Hz-80Hz, Q 0.5-4.0
ARC: Cut 0-15dB, Freq. 200Hz
OTHER FEATURES Remote Subwoofer Level Control Parallelable
ByPass Features
DIMENSIONS
Width 24-11/16"
Depth 9-5/8"
Height 2-1/2"
Boston GT275:
2-channel car amplifier
75 watts RMS x 2 at 4 ohms (120 watts RMS x 2 at 2 ohms)
1-ohm stable in stereo mode (150 watts RMS x 2 at 1 ohm)
225 watts RMS x 1 bridged output at 4 ohms (300 watts RMS x 1 at 2 ohms)
CEA-2006 compliant
variable high-pass filter (20-350 Hz, 12 dB/octave)
variable low-pass filter (50-350 Hz, 12/24 dB/octave)
Q-Tune technology for crossover adjustment
cooling fan
frequency response: 10-95K Hz
preamp-level inputs
fuse rating: 30A x 1
4G power and ground
adjustable mounting feet
8-3/4"W x 2-3/8"H x 9"D
3. Description/Condition:
MTX 91002:
I bought this amp off of somebody locally almost a year ago and was used to power 2 Type R's, gave me a demo and never saw below 12.8V. I have recently tested it to confirm it still works. Also the allen key screws for power and ground are missing but I will get new screws for them upon request.
Mechanically: 9/10 (used)
Cosmetically: 7/10 (Few small scratches also missing screws)
Boston GT275:
This amp is LBNIB. I bought this amp brand new. I opened it and have had it sitting around since. Never used it because plans had changed. I have not powered it but will upon request.
Mechanically: 10/10
Cosmetically: 10/10
4. What you are looking for: :
Looking specifically for a beefy 8 or 10 that takes around 1.5-2k, Also looking for a solid 4 channel that does 100-150 @ 2 ohms. But I am open to really anything car audio related
5. Pictures of your item for trade:
Text me anytime for more info/pics at 5857461905
Maybe, im good on wire and terminals for now but I do need a router //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Dang, all I got is wire and things no tools, you don't need any distros, fuse holders, batt terms etc?
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
440
6
504
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
885
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
snoop3111
snoop3111
Rochester, NY
snoop3111
Decebal
    Jun 10, 2024
