WTT 2 hifonics zeus zxi 60.4 +1k amps
  • 1
aliandjohn
hi all i have 2 HIFONICS ZEUS ZXI60.4+1K 5 CHANNEL AMPS i like to trade for matching mono amps hmu in a email or text me at 614-312-1077
Specs are as follows:
A/B Class 4-Channel Power Output
•60 x 4 @ 4 ohms
•120 x 4 @ 2 ohms
•240 x 2 [bridged] @ 4 ohms
D Class Mono Channel Power Output
•475 x 1 @ 4 ohms
•750 x 1 @ 2 ohms
•1000 x 1 @ 1 ohms
General Features
•A/B analog class
•4/2 ohm stable
•Multi-channel 5/4/3 channel configuration
•Bass EQ with 45Hz bass boost and variable 0 to 10dB
•High speed ultra-fi MOSFET output devices
•PWM stability power supply
•Variable low pass, high pass, band pass
•RCA inputs and outputs
•Built-in systems diagnostics
•True RMS output
•Illuminated Hifonics logo
•Weight: 15View attachment 26551789View attachment 26551788
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
aliandjohn
aliandjohn
lockbourne ohio
aliandjohn
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
