Wtt///wts amp and subs
  • 4
kwitcherbichin
i got 2 RE XXX 12s there dual 2 ohm subs. both subs are in working condition but one sub blew a lead wire and now there is a small hole in the bottom spider. the wire has been reconnected with more lead wire and works fine. played it at full xmax to make sure it wouldnt come back apart.
looking for 375 for good sub and 300 for other sub due to the hole.
shows how small the hole on the spider.
another shot of the hole.
both subs
massive 2000.1 n4 the amp has some acid damage to the case, had a battery in the back and i didnt realize that it tipped over while i was going down the road. took the amp apart and there is no acid inside and the amp still works fine.
teh guts
300 obo on amp
throw trades out there also. i am considering anything
i got 2 RE XXX 12s there dual 2 ohm subs. both subs are in working condition but one sub blew a lead wire and now there is a small hole in the bottom spider. the wire has been reconnected with more lead wire and works fine. played it at full xmax to make sure it wouldnt come back apart. looking for 375 for good sub and 300 for other sub due to the hole.
both subs
teh guts
300 obo on amp
i really like that massive amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
210
412
494
kwitcherbichin
kwitcherbichin
stantonsburg, nc
schackel
