SOLD WTT/WTS Carputer w/ 7" touchscreen
  • 4
csu87
Ive got my carputer with 7" touchscreen for sale. Just not want i need/want. I really only use the audio portion of this so there are alot of features that go unused
Specs:
- 7" Lilliput Touchscreen installed into a double din housing.
- Computer With specs:
.. Intel Atom Processor
.. 160Gig Western Digital Hard Drive
.. 1 Gig of Geil DDR-2 Ram
.. Bluetooth Dongle
.. OBD-II USB to display real time info on screen about your car or check and delete trouble codes
.. Zonet Wireless G Adapter
.. Garmin GPS with Garmin Mobile PC
.. Wireless mouse and roll up keyboard
.. Front End currently installed is Centrafuse 3.1 ( Which costs about $100 alone )
.. Windows XP Pro
.. Intelligent DC-DC power supply
Has Centrafuse 3.1 to run everything. Windows XP pro. Garmin GPS, Bluetooth that will pop up incoming calls and speak through your speakers, WiFi antenna to connect wirelessly.
Also comes with an intelligent power supply. this allows you to connect directly to the battery without the need for an inverter. also has a delayed off setting that will shut down the system gently after the car has been turned off, and a voltage monitor so that if the voltage drops too low after the car is turned off, then it will shutdown the computer.
Mainly looking for a double din touchscreen unit. would like it to have navi and 4-5volt preouts.
$600OBO
no i have 2 3.5mm to rca connected to the 2 audio outputs and it works great. clean signal and no humming or anything
csu87
csu87
C Springs, CO
csu87
