Wut do?
  • 2
My pops gave me a sub box that has 2 12" Sony xplod XS-L1265G's and 2 Hertz DCX 690.3's. one of the Hertz speakers is fubar but the subs and 1 speaker works. The box has a boss ava1210 equalizer mounted on the back.
For situational purposes I would like to hook up the system to run directly to my phone. (The guy I bought the truck from screwed with the wire harness and thats a monkey I'm not trynna get into bed with)
So my questions are: what amp should I run? what's the best way to wire them to the amp? And how do I get around using the stereo?
Sub specs:MAX. INPUT POWER:1200W
RATED POWER:400W IMPEDANCE:4 OHM+4OHM FREQUENCY RESPONSE: 20Hz-3000Hz
Speaker specs:
Power Handling - Continuous W90
Power Handling - Peak W180
Impedance Ohm
Lol! Had never heard this expression. The fact that monkeypox exists and how it was originally transmitted makes it funnier.
You will need an amplifier, a 3.5mm to RCA cable(or a bluetooth adapter). If you want to use the subs in conjunction with 6x9s, you will need bass blockers to protect them. That is IF you use a 2 channel amp. It is better if you use a 4 channel. You have better control of power and frequency.
A recommendation for the amp?
Archie_the_Bald
Archie_the_Bald
New Orleans, Louisiana
Archie_the_Bald
    Jun 1, 2024
    May 31, 2024
