Who can spot what this guy did wrong?
That's a good guess but XBL^2 doesn't use split coil.you mean the fact that he isnt using a split coil? or is it split just looks like one..
Getting colder.not mounting the basket to the motor while preparing the recone?
Nailed it.Bwahahahaha
When you saw 11mm "gap" on a nearly 3" top plate that should have been a hint.
Dual gap.
He really should have just measured the depth on the OEM coil.
Not quite, as there are two distinct gaps within that height.Great example of a guy that knows just enough to be dangerous.
On this driver the gap is the total height of the steel above the magnet.
