XXX mids in a 3 way active setup...
  • 7
BassAddictJ
FL
.....two thumbs up. They're a little bit under powered, seeing an underrated 100w each, but still wang in thier pods. I'm definitly impressed with thier output and clarity, they also get waaay lower than any other 6.5 I've used. The 60hz-80hz range plays with much more authority, and the 100hz-150hz range is just silly nice. I'm still playing around with thier bandpass freq cuts. I have them around 50hz to 280hz ish. Best midbass output Ive used to date. I've heard mixed reviews about them in a typical door installs. I can tell you pods are the way to go.
they're ****....
I always wanted to use some. Dont think I am up to building some pods right now tho //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Happy to hear you like them!
pics of **** time pods
---------- Post added at 08:56 AM ---------- Previous post was at 08:55 AM ----------
i cant post se xy?
I still have a set of the original version xbl^2 xxx mids Ive yet to try out.
Well if you dont use them soon, you should sell them to me... I will gladly sell my Clarus set, and run an active set up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Not likely to be sold any time soon. And they aren't even my best midbass setup Ive yet to try. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
so far ive tried lpf 24db/240hz and hpf 12db/50hz.....and pretty much vice versa.....lpf 12db/220hz and hpf 24db/50hz....i think I like the second choice so far, but I still have some EQ tweaking and testign to do. Going active is like having an extra part time job.
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
I agree with DJ. Pro style speakers are designed for large ported enclosures and lack bottom end without an enclosure. Plus they tend to suffer...
I think you need like a 10x switch on an amp? You would need to bandpass the mids or something Pioneer network mode or similar? I know the new...
I have ran the 6.5’s, but not the tweeters. They were very smooth and had good low mid bass. They were perfectly happy being high passed at 75 hz...
BassAddictJ
BassAddictJ
FL
BassAddictJ
