J31Rob, I can't post spec sheets, as these are so old that any information online is very scarce. I can tell you the Zapco AG is the original Zapco Reference series, so the specs from the 200.2 are the same as this AG200
Total Power (14.4V @ 1kHz) Power
Dynamic (4W mono) 230 watts
.2% T.H.D. 205 watts
Rated Power / Channel T.H.D.+N
50 watts x 2 @ 4W
100 watts x 2 @ 2W
Bridged Mono
134 watts x 1 @ 8W .046% T.H.D.
205 watts x 1 @ 4W .12% T.H.D.
Frequency Response 20 – 20kHz, ± .12dB
S/N Ratio > 95dB
Transient Distortion (4W, 40W)
Slew Rate > 23 V/mS
Damping Factor > 166 @ 4W
Input Sensitivity
Balanced (DIN) 500mV – 10V
Unbalanced (RCA) 250mV – 5V
Separation > 64dB
Max. Current Requirements 26 Amps @ 200 watts
Idle Current .84 Amps
Dimensions 11”L x 7.5”W x 1.95”H
As for the US Amps USA-150, I have never once seen a specs on that amp. But this is one from way back in the day. It says on it 150 Watts RMS, but I can comfortably say it puts out more than that (I'd say in the 300ish range). It pushed my 12" idMAX very nicely for the past 9 years or so.
EDIT - YES, they're both 2 channel amps. Both can be bridged to 4 ohms mono safely.
