ZED Audio Draconia III Lightly Used w/warranty
Vertex Audio
Pro Seller
Supporting Vendor
1,308
Los Angeles
Just got in a like new ZED Draconia III. An awesome amp for nearly every set up.
9/10 cosmetic with exception to a small chip.
Works 100%
Rated power is 175 watts x 4 into 4 ohm or 250w x 4 into 2 ohm
Bridged power is 350w x 2 into 8 ohm or 500w x 2 into 4 ohm
The pairs of channels are independently bridgeable
Two or four input configuration
Channels 1+2 feature 24dB per octave Linkwitz Riley High and Low Pass crossovers
Channels 1+2 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass
Channels 3+4 feature 24dB per octave Linkwitz Riley High and Low Pass crossovers
Channels 3+4 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass
Channels 3+4 in addition feature SUB MODE which introduces a 24dB per octave variable subsonic crossovers and a 40Hz constant Q equalizer
Level controls accommodate input levels up to 8.0v RMS
Pre-amplifiers utilize a fully isolated power supply for zero ground loops.
Pre-amplifiers drive the main amplifiers in a fully balanced mode.
Class D amplifiers utilize high-speed high current low gate charge MOSFETs.
Fully regulated power supply delivers power independent of battery voltage.
There are a total of thirteen regulated power supplies.
The power supply utilizes six 110 amp MOSFETs in a source follower configuration for maximum bandwidth.
Low ESR 105°C capacitors are used in the power supply.
Very high efficiency owing to the smart power supply.
Tiffany RCA's with Teflon inserts are used for ultimate quality and reliability.
$475 shipped to you
FREE
  • Locked
I don't suppose you have a spare Zed mikro IV in your collection? I'm conveniently located in central Florida and have cash on hand, lol. Matt
6
3K
A Link would be very helpful. Id be interested in taking a look at some gear
220
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
341
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Vertex Audio
Pro Seller
Supporting Vendor
Vertex Audio
Los Angeles
dailyrider123
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
