zx2500, and wiring Questions
  • 1
Jerhemy
WI
Hey Guys,
I'm pretty new to this forum and I just wanted to see what you all thought about running 2 sa 15's off a kicker zx2500.1 at 2 ohm? They will be getting at least 1200 rms each from the amp, is this too much for these subs, as they are labeled at 600 rms? I really didn't think it would be an issue at all because of the great things I had heard about sundown audio, but I just wanted to be sure.
My other question has to do with the grouding of my drycell in the back by my amp. I ran 2 runs of 0 gauge knukoncepts power wire from the front battery to the rear of my jeep. my question is whether or not I should run two runs of the same 0 gauge to the chasis as the ground. i know that a lot of people like to run a ground from the front battery to the rear battery but I figured I wasn't running enough amps to cause the chasis ground to become the 'choke point' of the electrical system.
Any info in general would be great as I am still learning lots.
Thanks!
Think i figured out the grounding, going to just run two negatives to match the positive runs.
Any input on the sub-amp combo would still be great,
Thanks!
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
245
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
647
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
672
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
670
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
574
Jerhemy
Jerhemy
WI
Jerhemy
Decebal
    Jun 10, 2024
