Amplifier -- Sub -- PSU -- Speakers
  • 2
youdoofus said:
i know youve said it several times, but the diagram on your psu says there is one. so youre either missing it, the sticker is lying or the black on the yellow wire has worn off. do you have a dmm?
you are right
it may be that it is consummated and I do not see it or see it only yellow
yes I have a DMM
What should I measure to identify the cables?
how do I put the psu in safety?
Do I have to connect the frame with a cable to the ground or do I have to put it in a wooden box?
if I connect the 2 cables with different amperage and their sum gives me about 22A after I have to put a bigger type 1.5 or 2.5 mm cable?
the fuse higher than 22A?
Thanks
you are right
yes I have a DMM
Thanks
just find all the 12v ones and combine them
huh?
no, it will provide the sufficient ground it needs inherently by the inverter based on the + voltage it outputs.
sum them as close as you can you the PSU, and use a bigger cable from there to connect your stuff
the total output will be 22a based on the diagram on the PSU
huh?
I did not understand how to use the dmm in amperage to measure the current on 12v
joining all the yellow cables I could not distinguish them
if I join the yellow cables of what should be the cable in mm or AWG?
on this larger cable the fuse than it should be? since I get 22A
the fuse must be greater than 22A? how much? the diagram of the psu I do not have it
you dont use a DMM to measure amperage, you use a clamp meter like this https://www.amazon.com/Fluke-323-True-RMS-Clamp-Meter/dp/B00AQKIEXY/ref=asc_df_B00AQKIEXY/?tag=hyprod-20&linkCode=df0&hvadid=312167987195&hvpos=1o1&hvnetw=g&hvrand=8862005689326562957&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9017953&hvtargid=pla-439349889262&psc=1
this one is pretty expensive, and you can get one for around $25 but for what youre doing, it shouldnt be necessary. Just know that the 14 + 8 amps will equal 22 amps of max output
 What? from where you join them to what youre connecting them to? if thats what youre asking, 8 awg should do it plenty fine
fuse it at 20 to be safe, but 25 will very likely be fine as well. id fuse it at 25 personally
the fuse should be at a level that prevents amperage higher than what you want to be thrown at your equipment to be. in this case, it would mainly be to prevent a amperage spike if the PSU goes out and spikes temporarily
I have identified the two + 12V cables with the DMM now I know which ones are at 8A and at 14 A
to power the radio I'm using + 12V 8A
are they enough or should I use the 14A one?
(at the moment the radio turns on and it works)
so you need to connect all the yellow cables and then put a 25A fuse with an AWG8 cable?
(since for the radio it is sufficient to use the 8A one)
if I connect the yellow cables the power supply to the radio must come from the biggest cable AWG8?
the other cables (red, black) I have to connect them together or I leave them free?
connecting the various yellow + 12V cables I would not have the sum of currents above 22A since each cable carries respectively 8A and 14A
(example sum 4 yellow cables all from 14A I get 14Ax4 = 56A)
No. A Dual 1 ohm subwoofer will only wire to 0.5 or 2 ohms. 4 dual 4 ohm subwoofer will wire to 1 ohm or 4 ohms. Again it's still a monoblock...
13
https://www.ctsounds.com/collections/ct-series-amplifiers There was a Sale recently.. May want to wait for a Thanksgiving Sale or Halloween Sale...
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
418
varano_ohms
varano_ohms
Los Angeles, CA
varano_ohms
