Upgrading car speakers with stock hu and amp
mmouse223
Is it better to go with same ohms as stock and just higher wattage? Any recommendations?
Acura now have 10 speaker 490 watts stock system now with 25 watts 4ohm speakers , would going with 65-100w at same olms and getting better tweeters make it louder and clearer , already added a 500 watt sub .
most tweeters and mids are 4 ohms. fwiw, most amps put out more power the lower the impedance, so you could get 2 ohm speakers and get more power for your $, but some amps arent stable at 2 or 1 ohm
spending more power to stock speakers might cause problems. yould have to know theyre power handing, or you could damage them
No, and they will most likely make it quieter. Now stock speakers are generally bare bones garbage, (but they are good enough for most people). They have a little bit to do with factoring into this as far as what you might personally notice, but I'll try explain the theory.
Sensitivity, is a rating which is a measure of volume. The sensitivity rating is measured at RMS wattage. So if you have two speakers that ARE RATED AT THE SAME SENSITIVITY, and one is 30w RMS and one is 100w RMS, (which generally doesn't happen, but the sensitivity will be close).
100w x 4 (ohms) = 400. Square root of 400 is 20 VAC (power supplied to reach wattage).
30w x 4 (ohms) = 120. Square root of 120 is 10.9VAC
25w x 4 (ohms) = 100. Square root of 100 is 10VAC
(here is a video that explain how voltage converts to watts)
You are not adjusting a gain, you're only variable is the volume control, and your output is minimal. So lets say maxed out that head unit/or amp, puts out 25w.
30w RMS speakers that have a sensitivity of 87 are going to get to 10/10.9 = 91% of their voltage needed to make that sensitivity.
If you have 100w RMS speakers have even a sensitivity of 92db, they are only going to get half the voltage they need to make rated sensitivity. Powering 100w speakers with 25w will be the EXACT SAME thing as powering them with 100w, and then turning the volume way down, (the volume isn't evenly spread, but it's about as much as turning the volume down to half if they were powered correctly.
If you want to increase the volume, You're either going to: want a new amp for those speakers, OR you want to find really low wattage speakers with a high sensitivity.
An aftermarket 2 ch amplifier with more power(100-200 rms @4 ohms) and aftermarket speakers(components of 100-150 rms each side) up front alone is going to be the best results without large disappointment ,time consumed, frustration and without digging a hole in the pocket.
Ok thanks I’ll look into if this can be done at reasonable priced or at all in a Acura with ELS system , I know some cars that come with stock amps are troublesome 😂
Ya man. Most those stock Hus are integrated to work more than the HU itsellf and a real PITA . especially on these newer vehicles with screens. i have an external screen i can take in and out of just about all my rides and use USB--or USB to aux input- a Laptop. LOL. I can even watch a Movie while listening to some tunes. LOL
Just wanted to add I having the same problem acura ilx have 7 speakers how can I find out if there is a stock amp in my front speakers or I heard in my head unit ?
Not sure I would just look at back speakers in back of trunk , if they say “ELS” on the back , I would assume there’s an amp somewhere , but not sure where. I can’t find much on YouTube about acuras
If you feel that the factory speakers in your car produce a dull sound lacking deep bass and clear, crisp highs, and if you don't want to spend a...
Do a lot of research using YouTube videos and other audio sites/forums. I also purchased several books on aftermarket stereo off of used books...
If you are not into the super loud sound with rattling bass then a quality headunit and speakers will suffice. Make sure the equipment is from a...
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
534
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
687
mmouse223
mmouse223
Louisiana
HardofWhoring
