Wire holders
CarAudio.com Regular
Will these work for a 3500 watt system to hold the cable down so they don't rattle? Or do I need some more stronger ones if so please suggest some
I use the plastic ones. They give a bit and won't interact should they manage to cut through the housing.
When you have a DSP unit, 4 amplifiers on an amplifier plate as well a 2nd battery, wire management becomes necessary if you want to keep everything organized. It also reduces the pull on the connections on the devices to almost zero.
Many people draw out their wire paths and drill holes on opposite sides and then use zip ties. I like those clamps, cause they're easy, look clean on wood or carpet and you can remove them and put them back should you need without having to pull the plate out.
Keeps things neat and tidy!
I went ahead and removes the door panels and looks like the 2024 is same as 2023 Rear Left Yellow + Brown - Rear Right Orange + Gray - And you...
161
All ofc cable by gp car audio 1 piece 1/0 red 14ft 1 piece 1/0 black 7 ft 1 piece 1/0 black 3ft each 5 pieces 1/0 red 2 ft 1 piece...
T-taps wiggle loose and give static when they do. Posi-taps are too fancy. I just peel a bit with a wire stripper and wrap the splice on that...
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
Charlotte
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
