12" Sub option
  • 4
fraser_2k5
Ello everyone, i'm new to the forum, from the UK!
I'm wanting a 12" sub with main focus on spl but would also like some sq, i was looking at either the kicker L7, or the R.E. SE. I would prefer to use a sealed box but could build a ported if it would make a big increase in sound performance. Would either of the subs be a good choise for me? Do many people here run either of these subs? Or if not could anybody reccomend anything else for around that price range (things are alot more expensive over here than in the US)?
Many thanks. //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
P.S the sub will have 1000w rms available to it @1 ohm or 600wrms @4hom
Thanks for the help, the SX is abit out of my price range, its aroung £300 pounds (which with the current exchange rate would work out at nearly $600 for you guys), whereas i can get an L7 for £200
You indicate it was installed? Why did the installer not go over the settings with you? They didn't set everything up? What is the system? Did...
404
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
757
fraser_2k5
fraser_2k5
England
fraser_2k5
edweather
    Jun 27, 2024
edweather
    Jun 27, 2024
