2 CHannel Amp to 4 Speakers?
  • 2
Another thing you could do is,run the amp to the front and run the rear off headunit if that's what your doing.
No im going to get 4 aftermarket so I want more than headunit power, and that is what I was thinking was 2 left and 2 right. Thank you very much
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
845
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
Wiring question....using four 4 ohm speakers and one 2 channel amp capable of 2.ohm load... Using 2 ohm stable 2 channel 4 ohm amp to power four...
RChillin
RChillin
Kansas City
RChillin
