2 component sets on 4 channel
Are the cdt's 2ohm or higher ? new components 2 ohm or higher ? not sure why you would want to, but you can. Amplifiers don't care how many drivers they are powering as long as the impedence load is high enough for the amplifier to handle //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Then yep. Unbridged your amp will handle 1.5-4ohm and put out the same power , you can do eet. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Sound deadening and door preparations are key to getting the best results towards more SQ oriented within the vehicle, as well as speaker locations
I ended up going with the Infinity Reference 6.5 component set up front, and polk audio dB 522 coaxial set in the rear. All of them powered by a...
29
3K
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
bigbear25
bigbear25
MIAMI
ramos
winkychevelle
    Jun 3, 2024
