USMC_Metallica
k my crossover isnt turning off like everything else when i shut my engine off, therefor draining my battery. i bought a simple on/off switch and put it in the pos wire until i can take it to a shop. its getting its pwr and rem from my h/u so is the prob most likely with the h/u or inside the x-over?
the 2nd is with my sub amp. it aint turning on! have a 1/0 wire going to a dist block and from there a 4 ga goin to my components amp and a 4 ga going to the sub amp. i hooked the sub wire to a diff terminal in the dist block and still nothing. i dont have a 12v tester so heh i stuck my allen wrench in the screw of the 12v side and it sparked wonderfully whilst i loosened it so it is getting pwr. didnt check the neg however there were no sparks when i loosened the remote screw. i have a rem going from h/u to component amp to sub amp. i checked and the rem wire is still secure at both ends. i couldnt do any further investigation because i dont have the right size open end wrench to take the screw out so i can unplug the 1/0ga from the batt. i need an 11mm but it seems like no one wants to sell that size individually. //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
not sure if this is the cause fo sho, but one day i had my truck's back window open (the sub amp is on top of my sub box, right by the window) and it began to rain rather suddenly. amp only got a tiny bit of water on it and most of the top is perforated. didnt smell any smoke or see sparks when i started engine up. also on a different day my dist block came unsecured and bumped into my sub amp and made a LOUD pop. could either have these been the ultimate doom for this thing? tis still under warranty but i dont have the papers or the packaging. got it off of ebay and left both in tx when i drove to north carolina //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif but ive sent an MA audio amp off before without the shop asking for proof of the warranty and i got back a new updated model and didnt have to pay but for shipping.
one last thing then im done i swear. on my batt i have a side terminal but the screw is too fat to fit through the ring terminal i have on the 1/0ga. i could simply just drill the hole bigger right? BUT i may not need to since i have two screws i can put stuff on on the terminal thats on the actual batt post.
