2014 Impala subwoofer problem
T Bird 27
MN
I have 2 15 inch obsidians wired at 2 ohms in a custom box tuned for 28-32 hertz, also, I have a db audio 2 farad capacitor with a db audio audio equalizer wired to the two front speakers into the factory system 8 inch display screen. I have the equalizer turned around 1/4ths its full range and the whole system resets within a matter of seconds and starts back up again. It will do this for awhile and when I leave it turned down it still usually plays and I usually don't have that problem. It's just when I've got it turned up that it cuts out. Would this be because of a stock battery issue? I have no idea why it does and I figured I'd post on here and try and find out...
*Car Audio Rookie*
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
816
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
5
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
8
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
T Bird 27
T Bird 27
MN
luis_88
Dylan27
    Jun 5, 2024
HandsomeSteve
    Jun 5, 2024
