3 way component build
Hello I'm new to this site and am seeking advice on building a 3 way component system and these are the options i would like to pursue.
Option 1 is i have a focal 5 1/4 2 way component system and would like to ad an 8'' midrange driver to this and was wondering if there is a 3 way crossover I can buy to have the 3 way component setup so I run these speakers off of 1 channel as opposed to adding an amp for the additional 8" midrange driver.
Option 2 would be to buy a new setup if anyone has some creative ideas it would be very helpful and please keep in mind that i don't have $800-$2000 to spend on a component set thanks
Focal has several 3-way sets with passive crossovers of which you can get just the xover alone. Part #XO /165AS3 should cost you bout $70.00 bucks or so from an authorized Focal dealer.....
You could get better sound by running the 8" mids active on their own amplifier channels, and add a digital signal processor to set up the crossovers, time alignment and EQ. CDT makes 2 crossovers that could be used with 8" and 5-1/4" speakers plus a pair of tweeters, but you need to consider more than just the crossover settings. Impedance matching is also important, and mixing and matching speakers with passive crossovers is a poor idea.
So if you can answer this question I would appreciate it.
I have an Xtant 4004a that has 50 watts pet channel in 4 ohm and 100 watts per channel in 2 ohms, so would it be a bad idea to run the 8s on the same channels as the focal components and I would be running those 2 channels in 2 ohm load? If I did this would affect the performance of any said equipment and if needed I could get an equalizer
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
960
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
robinhood81647
robinhood81647
new castle colorado
robinhood81647
