Advise with wiring eight 4ohm loads
  • 3
x91evo
Elemental Designs Nine.5:
RMS Power @ 12.5v : Front Channels
4 x 100 @ 4Ohm @ 0.05%THD
4 x 55 @ 8Ohm @ 0.05%THD
4 x 175 @ 2Ohm @ 0.05%THD
2 x 350 @ 4Ohm @ 0.05%THD
RMS Power (Subwoofer Channel) @ 12.5v :
1 x 250w @ 4Ohm @ 0.09%THD
1 x 450w @ 2Ohm @ 0.09%THD
1 x 600w @ 1Ohm @ 0.09%THD
I am on 16.5 volts charging (YES this amp can handle this voltage)
so I figure the real power will be a little more..
I went with 2 sets of Rockford Fosgate T2652-S components
Each of the 4 tweeters (4ohm) is rated at 100RMS and 200MAX
Also each mid (4ohm) is rated at 100RMS and 200MAX
The nine.5 has crossovers built in for channels 1-4
but also the rocksfords came with 4 crossovers that have a protection circuit for the tweeters.
Could someone help me decide how to wire this please?
I went over every variation on paper and cannot seem to figure out something that works
Series parallel would put my amp at this?
wouldnt that make it instantly bridged? since there would only be two of the four channels used?
---------- Post added at 08:53 PM ---------- Previous post was at 08:52 PM ----------
im a noob to electronics.. :,(
2 set of speakers per channel @ 2 ohms. Run tweets off front, mids of rears. Sub for sub if you have one.
---------- Post added at 08:59 PM ---------- Previous post was at 08:59 PM ----------
You better get ready for that amp to get warm playing a 2 ohm load through all channels.
yea but I have 4 tweeters @ 4ohm
and 4 mids @ 4ohm
do not want to overpower them
you designed me a box! you still have that thread active I got some pictures
you tell me haha
and i will get right on that
in total my setup has 4 external crossovers
4 mids
4 tweeters
sorry if im confusing lol
and then the internal crossover in the amp itself
looks like it pairs 1,2
then 3,4 together with the bp?
---------- Post added at 09:34 PM ---------- Previous post was at 09:33 PM ----------
i was thinking i dont really need the rockford crossovers?
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
235
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
You can just change the surround if the cone is not broken. This picture shows all the measurements you must make.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
197
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
264
x91evo
x91evo
Chicago IL
Buck
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
