Aftermarket speaker selection help.....Please!!
aea151
23
here
Here is the background:
I'm currently pushin' a Suburban with factory 6 1/2's" in the front doors, 6 3/4's in the rear doors and 4X10's in the upper rear pillers. I have a Mmats Juggy 15' being pushed by a Mmats D100HC. Factory Deck and all.
I am planning to go aftermarket on the interiors:
I was told to shop for a pair of components for the front. A pair of coaxials for the rear and leave the 4X10's on the deck.
1) What would you guys recommend?
2) How good are the Mmats speakers/Components?
3) Should I even try to keep the factory deck with the signal booster?
4) What are some good brands if I am working with a $400 budget for all speakers...(excluding the amp...but Im thinking about the 4 channel Mmats)
Thanks.
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
If you can tap before the Bose amp, then you may only need a simple LOC. If you tap after the Bose amp, then you will need a bass restorer/LOC...
That being the case, then we can rule out something in the ECU being shorted out because of the wiring. Although I do wonder if the ECU needs a...
10
806
aea151
aea151
here
aea151
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
