Amp for Orion system?
  • 2
Hi all,
Fairly new to the car audio scene, so, after many hours of fruitless research into possible solutions, I have decided on the 'direct question method'.
So, here's the deal. I'm an extreme basshead, and I have chosen to kit out my 1979 Honda Civic with a single Orion HCCA 15.2 subwoofer. (I have extensively researched this sub and understand its power-hungriness etc.). Also, to follow suit with the Orion brand, I have decided to go with two Orion HCCA88N midrange drivers and two Orion TN-1 Bullet tweeters. Now, seeing as I'm about as technically minded as a tree, I need help with literally every other part of my system. (Head unit, wiring gauges, capacator or not, amplifiers, anything else...) My main question is what amp do I need for my sub (thinking monoblock single channel) and which for the mids and tweeters (decided on separate amps). Any general advice is GREATLY appreciated. Thanks in advance,
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
195
6
407
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
717
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
516
Bassaddic
Bassaddic
Norfolk Island, Aus
Bassaddic
winkychevelle
    Jun 3, 2024
