Jeffdachef
Gunz That Turn on Nunz
two 100 ah northstar agm = 22ah jy power lithium.Is there a direct AH ratio for comparison? Like 100AH AGM is equivalent to 25 AH L-Ion?
I believe you, but cant see how.two 100 ah northstar agm = 22ah jy power lithium.
You cant compare them to an agm battery specs wise its totally something different on another level.I believe you, but cant see how.The capacity is only 10%
How long do these last? Are they as reliable as AGM?
For me its about space savings. 22AH $750! I cant do that thoughYou cant compare them to an agm battery specs wise its totally something different on another level.
They last just as long if not longer.
Everyone that swapped to lithium gained at the minimum one whole db over agms.
now you see the tradeoff lol. Still a nortstar sms 480 costs the same but performs less and its 10x the weight and is very big real estate wise.For me its about space savings. 22AH $750! I cant do that though
Are other Lithium batteries brands ok to use? Like maybe the Lithium motorcycle batteries?now you see the tradeoff lol. Still a nortstar sms 480 costs the same but performs less and its 10x the weight and is very big real estate wise.
i'd trust jy and limitless atm. Some off brand lithiums are pretty junky.Are other Lithium batteries brands ok to use? Like maybe the Lithium motorcycle batteries?
I do some research on the "C" ratingi'd trust jy and limitless atm. Some off brand lithiums are pretty junky.
You want something with a High C rating. Cheap lithiums will be under 5C while good ones are above 10c.
The cheaper lithiums will require a lot more just to keep up and its slow to charge back up as well.
I am trying to find out if other brands lithium are good as well.You can't really judge a battery for car audio by the AH rating. The Limitless 22ah lithium is a nasty battery.
