Amp not powering on
  • 4
jochua
AZ
As stated above I have a Planet Audio 1600 watt two channel amp. i had it for a while but stopped using it because a sub went out, I just got a new sub and installed it, and installed the amp (I left all the wires in the same place) and when I turned on my car nothing. So the first thing I checked were the wires. There was power going from the battery, through the terminal, and all the way to the end of the wire, going into the amp. Then I checked the ground, the ground was being completed. Last I checked the fuses (The big fuse is obviously fine if the power is going to the end of the wire) I checked them and they were fine but I replaced them anyways and still nothing. I took my amp apart and tried looking up some troubleshooting videos but I couldn't find much for my amp or problem, and I know nothing about the amps. Is my amp screwed or can I repair it?
Did you check your source. Are the RCA cables from the headunit to the amp connected? I'm assuming that your other speakers are working? If all your wiring is correct, I suspect there is something wrong with the amp. Let us know when and how you solved the problem.
Some things that your missing need to be addressed; i.e. RCA's as huberoy123 said, remote wire connect to remote on back of HU, ground properly, just to name a few things.
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
788
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
6
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
161
6
393
jochua
jochua
AZ
Boomin_tahoe
