Amp question
  • 3
floridaguy727
I'm replacing a diesel 440 watt 2 channel amp it has a 8 gauge power cord. I'm replacing with a xpr 540 dual do I use the same 8 gauge power or do I need to change because this amp is 1200 peak. I know this isn't the greatest amp but it was free and its just temp. its pushing 4 kickers 2 6.25 2 6.5 from 2006 not 100% of wattage on them. right now the amp is a 2 channel bridged I'm going to undo them and turn them into a 4 channel. any suggestions complete noob.
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
697
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Haven't 100% landed on which one, but I am down to those two
12
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
floridaguy727
floridaguy727
arkansas
floridaguy727
