R rammstein 10+ year member Junior Member 23 0 AZ Oct 5, 2008 #1 I have one sub DVC @2ohms per x 1200watt I can get an amp that puts out 1200 @ 1ohm load and another that puts out the same but @4 ohms both amps are 1ohm stable Click to read more...
Horsemanwill 10+ year member CarAudio.com Veteran 3,000 0 Junction City, Kansas Oct 5, 2008 #2 so pick one
OP R rammstein 10+ year member Junior Member 23 0 AZ Oct 5, 2008 Thread Starter #4 is there an advantage or going with the one that puts out 1200 @ 4ohm than the one that puts out same @1 ohm? would the amp that puts it out @ 4ohm be more true power instead of the one that puts it out @1ohm in other words over inflated numbers vs true output
Gearstix 10+ year member CarAudio.com Elite 837 0 Alberta, Canada Oct 5, 2008 #5 poast the amp manufacturer/models the 4 ohm one should have better SQ
shaneb 10+ year member CarAudio.com Veteran 2,559 0 Fort Worth, TX Oct 5, 2008 #6 it's 2 ohms per coil? if that is the case then get the 1ohm amp, but a 4ohm amp will allow you to add a sub in the future...
Horsemanwill 10+ year member CarAudio.com Veteran 3,000 0 Junction City, Kansas Oct 5, 2008 #7 it's all dependable about how the amp was designed some amps like 4 ohms better then 1 but at the same time some amps are designed to run 1ohm so it wouldn't make a difference
OP R rammstein 10+ year member Junior Member 23 0 AZ Oct 5, 2008 Thread Starter #8 PA amps BAMF 2000/1D 1200 @ 1 Ohm other is BAMF 4000/1D 1200 @ 4 Ohm and yeah yeah there power acoustik amps apparently not that great of an amp
Lothar34 10+ year member Donations Accepted 108 0 Pearland, TX Oct 6, 2008 #9 I have the 2000/1D and I seriously doubt it will put out 1200W. Better to get one of the bigger ones and run it at 1ohm.
OP R rammstein 10+ year member Junior Member 23 0 AZ Oct 6, 2008 Thread Starter #10 they "say" that the BAMF 4000/1D @ 1ohm is 2200 but i only need 1200 the BAMF 4000/1D says 1200 @ 4ohms
OP R rammstein 10+ year member Junior Member 23 0 AZ Oct 6, 2008 Thread Starter #12 MOFO-12 * 2400 watts power handling * 1200 Watts RMS * 270 oz . magnet * 3¡± BASV/Kapton Hybrid 18 AWG Voice Coil * SPL 90 dB * Fs: 36.7 Hz * Vas: 0.73 cu.ft. * Qms: 5.34 ? Qes: 0.36 ? Qts: 0.3363 * Xmax: 0.7" * Sealed box: N/A * Ported box: 2.4 cu..Ft. * Tuning: 40 Hz * Port size: 3¡± (dia)x 6.75¡± (length) * # of ports: 2 * Mounting Depth: 6.75¡±
OP R rammstein 10+ year member Junior Member 23 0 AZ Oct 6, 2008 Thread Starter #13 MOFO-12 * 2400 watts power handling * 1200 Watts RMS * 270 oz . magnet * 3¡± BASV/Kapton Hybrid 18 AWG Voice Coil * SPL 90 dB * Fs: 36.7 Hz * Vas: 0.73 cu.ft. * Qms: 5.34 ? Qes: 0.36 ? Qts: 0.3363 * Xmax: 0.7" * Sealed box: N/A * Ported box: 2.4 cu..Ft. * Tuning: 40 Hz * Port size: 3¡± (dia)x 6.75¡± (length) * # of ports: 2 * Mounting Depth: 6.75¡±
OP R rammstein 10+ year member Junior Member 23 0 AZ Oct 6, 2008 Thread Starter #14 er that was not supposed to post twice sorry about that
Lothar34 10+ year member Donations Accepted 108 0 Pearland, TX Oct 6, 2008 #15 they "say" that the BAMF 4000/1D @ 1ohm is 2200 but i only need 1200the BAMF 4000/1D says 1200 @ 4ohms Click to expand... Yeah, get the 4000 and run it at 1ohm.
