amplifier going into protect mode help?
  • 3
Only The Best
texas
so i have a rockford fosgate prime 5 channel brand new amp.... had it for 2 weeks running off of 2 6x9's... then i put 2 more on it today and tried to run it but then it kept throwing itself into protect mode any time it tried to hit a base note like the amp wasnt able to put out enough power to push the speakers... the wires are not grounding themselves out i know that.... the amp isnt broken i know that...would maybe a line driver help the situation? the gains are only set around 4-5 out of 10 so its not being overpushed i think because it doesnt get loud enough to really hurt my ears before it starts distorting.... please help ... thank you all for your input
would u mind throwing me a diagram or an explanation of what that wuld look like to make sure that i did it right?... im just a DIY'er here
four (4) ohm 6x9's wired to 4 ohms on a 4 channel all in the same box... wouldnt they all be just connected on the amp as you normally should? 1 pos to the pos on the amp. 1 neg to the neg on the amp
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
472
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
The CT's are nice, That Sundown is a a frik'n beast!
7
916
895
Only The Best
Only The Best
texas
Only The Best
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
