Basic Question about 5-Channel Amps (Please help!)
  • 3
plckle1
NJ
Very new here,
I have a basic question about my Pioneer GM-D9605 5-channel amp. I have combed through the user manual and cannot find any information on this.
What I want to know is if I do not connect anything to the 5th channel (subwoofer channel) will the amp work alright just powering the other 4 channels (I have components and coaxials on the other 4 channels)? I ask this because I want to upgrade my subwoofer to a dedicated mono amp and a new sub, but I still want the components and coaxials to work as they are right now.
And on a side note, if this does work, will the 5-channel amp draw less power as well because it is no longer pushing a subwoofer?
Thank you very much for any help
I've owned/installed a few 5 ch amps and almost all of them have a selector switch to disable the sub ch if the user chooses to run it as a 4 ch amp only. It's def not a problem, even if it didn't have a switch on it and you didn't hook it up to a sub, it'll be fine. The input select on the side of the amp is what your after, simply slide the switch over to the A/B side. Also has another switch to choose either 2 or 4 ch mode...put that on 4 ch and should be good.
https://www.sonicelectronix.com/pictures_new.php?id=100369&picture_id=2725241
Yep, boomin is correct, also yes, itll draw less current as the sub output wont be utilized and therefore not drawing any power to that part of the amp.
Hello All. Just a quick update as I don't want people think I am ignoring their top suggestions and comments. But I am at present putting this...
48
6K
I can't speak to carplay but I'm using a Joying unit for android auto. It's a single din slot with a screen that attaches. The single din units...
4
https://www.amazon.com/dp/B01EXOTD56/?tag=caraudiocom-20 Cant go wrong with these for the price and drop ins on HU power alone. They do much...
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
430
plckle1
plckle1
NJ
youdoofus
