Boschmann AZX-W10 Nuke (ported enclosure design help)
  • 3
jj_5_ff
6
main
Hello everyone, i recently got a "Boschmann AZX-W10 Nuke" woofer and i want to build a "Loud Ported box", with the lowest possible tuning, and fits into my Miata's trunk.
Maximum available dimensions:
Width: 18"
Height: 16"
Depth 1: 8"
Depth 2: 10"
(I know the manual says "use sealed box", but i hate sealed boxes hehehe)
Any Help ?
you can contact me on my email too jj_5_ff@excite.com
Thank you.
you build an enclosure around a subwoofer for the best results, not the other way around.
if you want a loud ported setup, sell that sub and get something oriented for ported with a lower Qts.
Thanks!
In your opinion, would it be loud in a sealed box?
and btw, i have no idea about all those parameters in the specs sheet hehehe what is Qts ?
thank you again, lots of parameters out there hehehe
actually, i needed a ported box, a loud one; someone suggested a box up to 1.5 cubic feet box (doesn't fit in a Miata's trunk), so i tried to post here, i thought maybe i could get an answer or advice for a ported box. anyway, i guess i'll go for 1.2 cubic feet Sealed box.
unfortunately if you're lacking on space like that sealed may be your only option - or using an 8 inch driver. it sounds like you want to keep your current sub so id recommend a custom sealed enclosure (prefab boxes leak)
that sub looks like it can take some decent power, so get it a quality amp and I think you'll be happy.
thank you for the quick reply ,I contacted LordofBass and the part is backordered but I'm on a waiting list Cheers:)
jj_5_ff
jj_5_ff
main
wew lad
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
