Box for Fi Q15
  • 5
Ok so I have pretty much made up my mind that i am going to try to get the Fi SSD 12 at 2ohm. I would want want build my own ported box. I have never really tried to make a box so I would need some help with designs. In the end I will want the box to just be painted black an then have a strnciled Fi logo in blue on the side to match the dustcap. Last part was just an idea
Most of the time a Kerfed port will not make a massive alteration to the sound you actually hear. It can but the likely hood is very small. They do look better though.
As for doing the enclosure yourself, there are several vendors and members here that do designs but most of us charge for those but they are easy to follow and will normally yield an overall great product assuming your craftsmanship is on par with the design.
As for you ideas on painting and logos. Here are few pointers for you to consider when painting and such.
1. Sand away any imperfections from building then enclosure.
2. Bondo all seems to hide them and make the enclosure..well...seemless..
3. A good way to do the logo is to first primor the whole enclosure. Then pick out the area you want the logo to be and paint a larger area then the logo will be with blue paint. Lay down a vinyl graphic decal of the logo/design you want blue. Once you have done that paint the whole enclosure black with the decal in place. Give the paint time to set and then pull the graphic off which should reveal a blue logo if done correctly. Then clear it and your done.
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
565
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
685
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
816
Sketchup
Sketchup
Iowa
Sketchup
winkychevelle
    Jun 3, 2024
