Trixter
Keepin it Simple
I'm just wondering if anyone has ran a Cadence A7hc with a line driver? If so what is the difference? How is the outcome? Bottom line: should I get one??
True, but most HUs are only 4v. Ive noticed a clearer front stage with my D. Navone LOC/Line Driver. I believe it also puts out a balanced signal. Both my friend and I are using factory radios.for a while i was running two american bass CX1200D's, which i believe are the same boards as the cadence amps, and i hda an audiocontrol line driver on them. i only used the line driver for SPL comps, and it helped out my score a good bit. id say for competitions, go for it, but for daily, its not neccesary. if you need more voltage through the RCA's the best option is the HU
